Ga door naar hoofdinhoud
Whirlpool Dryer Main Board Replacement
Wat je nodig hebt
  1. Whirlpool Dryer Main Board Replacement, Safety Precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Main Board Replacement, Unfasten the top panel: stap 2, afbeelding 1 van 3 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: stap 2, afbeelding 2 van 3 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Main Board Replacement, Remove the top panel: stap 3, afbeelding 1 van 2 Whirlpool Dryer Main Board Replacement, Remove the top panel: stap 3, afbeelding 2 van 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Main Board Replacement: stap 4, afbeelding 1 van 2 Whirlpool Dryer Main Board Replacement: stap 4, afbeelding 2 van 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: stap 5, afbeelding 1 van 2 Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: stap 5, afbeelding 2 van 2
    • Disconnect all the wires from the main board.
  6. Whirlpool Dryer Main Board Replacement: stap 6, afbeelding 1 van 3 Whirlpool Dryer Main Board Replacement: stap 6, afbeelding 2 van 3 Whirlpool Dryer Main Board Replacement: stap 6, afbeelding 3 van 3
    • Continue disconnecting the main board.
  7. Whirlpool Dryer Main Board Replacement: stap 7, afbeelding 1 van 3 Whirlpool Dryer Main Board Replacement: stap 7, afbeelding 2 van 3 Whirlpool Dryer Main Board Replacement: stap 7, afbeelding 3 van 3
    • Finish disconnecting the wires from the main board.
  8. Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: stap 8, afbeelding 1 van 3 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: stap 8, afbeelding 2 van 3 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: stap 8, afbeelding 3 van 3
    • Using a flat head screwdriver or a spudger, release the cover clips.
  9. Whirlpool Dryer Main Board Replacement, Remove the main board cover: stap 9, afbeelding 1 van 3 Whirlpool Dryer Main Board Replacement, Remove the main board cover: stap 9, afbeelding 2 van 3 Whirlpool Dryer Main Board Replacement, Remove the main board cover: stap 9, afbeelding 3 van 3
    • Lift the cover to release the tabs on the opposite side of the main board housing.
    • Remove the cover.
  10. Whirlpool Dryer Main Board Replacement, Release the main board: stap 10, afbeelding 1 van 3 Whirlpool Dryer Main Board Replacement, Release the main board: stap 10, afbeelding 2 van 3 Whirlpool Dryer Main Board Replacement, Release the main board: stap 10, afbeelding 3 van 3
    Anti-Static Wrist Strap
    $7.95
    Koop
    • There are six retaining clips securing the main board. Start at one end and work towards the other.
    • When you're handling the main board, wear an anti-static strap if possible, or regularly touch the exposed metal parts of the dryer to prevent electrostatic damage to the board.
    • Lift the board with one hand and use the other to release each clip with a spudger.
    • As you go, keep a gentle upward pull on the board so that the released clips don't snap back into place as you work.
    • Alternate sides of the board when releasing the clips.
  11. Whirlpool Dryer Main Board Replacement: stap 11, afbeelding 1 van 2 Whirlpool Dryer Main Board Replacement: stap 11, afbeelding 2 van 2
    • Release the remaining clips until the board is completely separated from its housing.
  12. Whirlpool Dryer Main Board Replacement, Remove the main board: stap 12, afbeelding 1 van 1
    • Remove the main board from its housing.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30.088 Reputatie
213 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 104
