Ga door naar hoofdinhoud
WarioWare: Twisted! Rumble Motor Replacement
Wat je nodig hebt
  1. WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: stap 1, afbeelding 1 van 2 WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: stap 1, afbeelding 2 van 2
    • Use a Tri-point Y0 screwdriver to remove the single 3 mm screw located at the back of the game.
    • Remove the cover to expose the control module electronics board underneath.
  2. WarioWare: Twisted! Rumble Motor Replacement: stap 2, afbeelding 1 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 2, afbeelding 2 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 2, afbeelding 3 van 3
    • Heat up the soldering iron to approximately 350 degrees Fahrenheit.
    • Remove the rumble motor from the slot.
    • For more information on soldering, refer to How to Solder and Desolder Connections.
    • Apply the tip of the soldering iron to the connection points, causing the red and blue wires to melt and detach.
    • Separate the old rumble motor from the board and set it aside.
    • The soldering iron will be very hot. Do not touch the tip of the iron. It will cause severe burns.
  3. WarioWare: Twisted! Rumble Motor Replacement: stap 3, afbeelding 1 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 3, afbeelding 2 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 3, afbeelding 3 van 3
    • Use your hands to remove the black sleeve from the old rumble motor.
    • Set the old rumble motor aside.
    • Use your hands to place the black sleeve onto the new rumble motor you're using.
  4. WarioWare: Twisted! Rumble Motor Replacement: stap 4, afbeelding 1 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 4, afbeelding 2 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 4, afbeelding 3 van 3
    • Place the red wire onto the plus (left) side, and the blue wire onto the minus (right) side.
    • To reattach the red and blue wires, carefully bring the tip of the soldering iron into contact with the connection points.
    • The soldering iron will be hot. Do not touch the tip of the iron.
    • Place the new rumble motor back in its slot.
    • Turn off the soldering iron after you finish this step.
  5. WarioWare: Twisted! Rumble Motor Replacement: stap 5, afbeelding 1 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 5, afbeelding 2 van 3 WarioWare: Twisted! Rumble Motor Replacement: stap 5, afbeelding 3 van 3
    • Put the cover back on the game.
    • Gently push the two sides back together.
  6. WarioWare: Twisted! Rumble Motor Replacement: stap 6, afbeelding 1 van 2 WarioWare: Twisted! Rumble Motor Replacement: stap 6, afbeelding 2 van 2
    • Use your Tri-point Y0 screwdriver to screw the single 3 mm screw back into place.
    • Test the game to make sure the problem is fixed and you should be ready to play!
Conclusie
I hope this guide solved your problem, and your game should work like new again!
Één andere persoon heeft deze handleiding voltooid.
Brent Thompson
133 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Nice post and please provide more information. Thanks for sharing.
cunez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 74
Altijd: 1,417
