Inleiding
This is a guide on removing the light bulbs from their colored-plastic shell, but not replacing the bulb. Take care not to use too much force as the bulbs or wires may get damaged while being extracted.
Wat je nodig hebt
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
