Ga door naar hoofdinhoud
Wacom Cintiq 24HD USB Video Port Replacement
Wat je nodig hebt
  1. Wacom Cintiq 24HD USB Video Port Replacement, Stand: stap 1, afbeelding 1 van 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD USB Video Port Replacement: stap 2, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 2, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 2, afbeelding 3 van 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD USB Video Port Replacement: stap 3, afbeelding 1 van 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD USB Video Port Replacement, Back Panel: stap 4, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement, Back Panel: stap 4, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement, Back Panel: stap 4, afbeelding 3 van 3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD USB Video Port Replacement: stap 5, afbeelding 1 van 2 Wacom Cintiq 24HD USB Video Port Replacement: stap 5, afbeelding 2 van 2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD USB Video Port Replacement, Interior Metal Plate: stap 6, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement, Interior Metal Plate: stap 6, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement, Interior Metal Plate: stap 6, afbeelding 3 van 3
    • Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
  7. Wacom Cintiq 24HD USB Video Port Replacement: stap 7, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 7, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 7, afbeelding 3 van 3
    • Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise.
    • Remove the metal button plate from the back metal plate.
  8. Wacom Cintiq 24HD USB Video Port Replacement: stap 8, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 8, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 8, afbeelding 3 van 3
    • Remove the button wires from the support clip by pushing down on the clip.
    • Detach the button wires from the button board by pulling the button wires away from the board.
    • Place the button board back in to the device.
  9. Wacom Cintiq 24HD USB Video Port Replacement: stap 9, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 9, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 9, afbeelding 3 van 3
    • Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise.
    • Remove the two metal mounting plates.
  10. Wacom Cintiq 24HD USB Video Port Replacement: stap 10, afbeelding 1 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 10, afbeelding 2 van 3 Wacom Cintiq 24HD USB Video Port Replacement: stap 10, afbeelding 3 van 3
    • Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
    • Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
  11. Wacom Cintiq 24HD USB Video Port Replacement: stap 11, afbeelding 1 van 1
    • Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
  12. Wacom Cintiq 24HD USB Video Port Replacement, USB Video Port: stap 12, afbeelding 1 van 2 Wacom Cintiq 24HD USB Video Port Replacement, USB Video Port: stap 12, afbeelding 2 van 2
    • Remove the one 6.8mm Phillips #1 screw by turning the screwdriver counterclockwise.
  13. Wacom Cintiq 24HD USB Video Port Replacement: stap 13, afbeelding 1 van 1
    • Remove the four 8mm Phillips #1 screws with flanges by turning the screwdriver counterclockwise.
  14. Wacom Cintiq 24HD USB Video Port Replacement: stap 14, afbeelding 1 van 1
    • Remove the five cables connected to the USB board by pinching near the connector and pulling the cables straight out.
  15. Wacom Cintiq 24HD USB Video Port Replacement: stap 15, afbeelding 1 van 1
    • Remove USB video port by desoldering at the connection points on the board.
    • iFixit has a soldering guide that you can find here.
Conclusie
Jay Sung
481 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G3, White Fall 2018 Lid van Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 1,408
