Ga door naar hoofdinhoud
Wacker Pump PT3A 2012 Shock Mount Replacement
Wat je nodig hebt
  1. Wacker Pump PT3A 2012 Shock Mount Replacement, Disconnect the spark plug wire: stap 1, afbeelding 1 van 2 Wacker Pump PT3A 2012 Shock Mount Replacement, Disconnect the spark plug wire: stap 1, afbeelding 2 van 2
    • Before you begin, make sure the device is switched off and the engine is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Pump PT3A 2012 Shock Mount Replacement, Rotate the device: stap 2, afbeelding 1 van 3 Wacker Pump PT3A 2012 Shock Mount Replacement, Rotate the device: stap 2, afbeelding 2 van 3 Wacker Pump PT3A 2012 Shock Mount Replacement, Rotate the device: stap 2, afbeelding 3 van 3
    • If you are only replacing one or two shock mounts, you may not need to rotate the device.
    • Carefully rotate the device so that the pump sits on top of the engine.
    • Place a block of wood underneath the engine so that the engine weight rests on the wood and not the shock mounts.
  3. Wacker Pump PT3A 2012 Shock Mount Replacement, Remove the mounting bolts: stap 3, afbeelding 1 van 1
    • Do not remove all four mount bolts at once, or the assembly will separate from the frame. Replace up to two shock mounts at a time.
    • Use a 13 mm socket and wrench to remove the nut(s) securing the shock mount(s) that you are replacing.
  4. Wacker Pump PT3A 2012 Shock Mount Replacement, Remove the shock mount: stap 4, afbeelding 1 van 2 Wacker Pump PT3A 2012 Shock Mount Replacement, Remove the shock mount: stap 4, afbeelding 2 van 2
    • Use a 19 mm socket and wrench to remove the bolt securing the shock mount to the assembly.
    • Remove the shock mount.
    • Repeat to replace the remaining shock mounts.
Conclusie
Arthur Shi
254.032 Reputatie
529 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.259 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 197
