Ga door naar hoofdinhoud
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
Wat je nodig hebt
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: stap 1, afbeelding 1 van 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: stap 1, afbeelding 2 van 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: stap 2, afbeelding 1 van 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: stap 3, afbeelding 1 van 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: stap 3, afbeelding 2 van 2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: stap 4, afbeelding 1 van 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: stap 4, afbeelding 2 van 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: stap 4, afbeelding 3 van 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: stap 5, afbeelding 1 van 1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: stap 6, afbeelding 1 van 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: stap 6, afbeelding 2 van 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: stap 6, afbeelding 3 van 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
Conclusie
Arthur Shi
257.458 Reputatie
529 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 3,102
