Inleiding
Use this guide to replace the dispenser solenoid in your Whirlpool WRS315SDHW Refrigerator.
The dispenser solenoid controls, or actuates, water dispensing. If you're refrigerator won't dispense water properly, then the dispenser solenoid might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Wat je nodig hebt
Pull the icemaker tray completely out of its slot in the chassis.
Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
Two 23.9 mm-long screws
One 16.7 mm-long screw
Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
Let the icemaker assembly hang to access its connector.
Disconnect the spade connector attached to the icemaker assembly.
Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
Two 24.1 mm-long screws
Two 16.5 mm-long screws
Pull the icemaker auger assembly off of its slot in the chassis.
Let the assembly hang to access its connector.
Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
Use your hands to disconnect the assembly connector.
Slide the dispenser head out of its slot in the icemaker auger assembly.
Pull the solenoid spade connector straight out of the solenoid to disconnect it.
Repair didn’t go as planned? Ask our Answers community for help.
