Ga door naar hoofdinhoud
Vtech Kidizoom Smart Watch DX Circuit Board Replacement
Wat je nodig hebt
  1. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Master Switch: stap 1, afbeelding 1 van 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 4, afbeelding 1 van 2 Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 4, afbeelding 2 van 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: stap 5, afbeelding 1 van 2 Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: stap 5, afbeelding 2 van 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 7, afbeelding 1 van 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 8, afbeelding 1 van 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: stap 9, afbeelding 1 van 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jordan RiberSmith
797 Reputatie
2 handleidingen geschreven
USF Tampa, Team 10-6, Remmell Spring 2016 Lid van USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Leden
12 handleidingen geschreven
2Gids Commentaar
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Jamar Mckay - Antwoord
Where can I buy replacement and how much should it cost?
Marisol Pelayo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 49
Altijd: 10,834
