Ga door naar hoofdinhoud
Vtech Kidizoom Smart Watch DX Buttons Replacement
Wat je nodig hebt
  1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: stap 1, afbeelding 1 van 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 4, afbeelding 1 van 2 Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 4, afbeelding 2 van 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: stap 5, afbeelding 1 van 2 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: stap 5, afbeelding 2 van 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 6, afbeelding 1 van 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 7, afbeelding 1 van 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 8, afbeelding 1 van 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 9, afbeelding 1 van 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: stap 10, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the the tweezers to pull off the blue rubber cover behind the button.
    • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
  11. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 11, afbeelding 1 van 1
    • Use tweezers to separate the backside tab from the front side of the button.
  12. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 12, afbeelding 1 van 1
    • Push the other half of the button out of the casing.
    • Repeat steps 11 and 12 for all buttons.
Conclusie
Mohammed Alyaarubi
365 Reputatie
1 Handleiding geschreven
USF Tampa, Team 10-6, Remmell Spring 2016 Lid van USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Where can you buy the replacement cover?
Katrina Nullatamby - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 6,126
