Ga door naar hoofdinhoud
Vtech Kidibeats Drum Set Speaker Replacement
Wat je nodig hebt
  1. Vtech Kidibeats Drum Set Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Speaker Replacement: stap 2, afbeelding 1 van 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Speaker Replacement: stap 3, afbeelding 1 van 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Speaker Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Speaker Replacement: stap 6, afbeelding 1 van 2 Vtech Kidibeats Drum Set Speaker Replacement: stap 6, afbeelding 2 van 2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Speaker Replacement, Speaker: stap 7, afbeelding 1 van 1
    • Loosen and remove the two 10mm screws using a Phillips #00 screwdriver.
  8. Vtech Kidibeats Drum Set Speaker Replacement: stap 8, afbeelding 1 van 1
    • Using your hand, gently remove speaker from its housing.
  9. Vtech Kidibeats Drum Set Speaker Replacement: stap 9, afbeelding 1 van 1
    • Using a soldering station, carefully desolder the connection points on the speaker.
    • To review soldering safety and techniques, please visit Hoe moet je (de-)solderen?.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Klementowski
820 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-8, Cagle Spring 2016 Lid van USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 601
