Ga door naar hoofdinhoud
Vtech Innotab 3 Speaker Replacement
Wat je nodig hebt
  1. Vtech Innotab 3 Speaker Replacement, Rear Panel: stap 1, afbeelding 1 van 3 Vtech Innotab 3 Speaker Replacement, Rear Panel: stap 1, afbeelding 2 van 3 Vtech Innotab 3 Speaker Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Speaker Replacement: stap 3, afbeelding 1 van 3 Vtech Innotab 3 Speaker Replacement: stap 3, afbeelding 2 van 3 Vtech Innotab 3 Speaker Replacement: stap 3, afbeelding 3 van 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 3 Vtech Innotab 3 Speaker Replacement, Speaker: stap 5, afbeelding 2 van 3 Vtech Innotab 3 Speaker Replacement, Speaker: stap 5, afbeelding 3 van 3
    • After you disassemble the device, put the back panel to the side and move your attention to the front piece.
    • Remove the four screws using a PH00 screwdriver.
  6. Vtech Innotab 3 Speaker Replacement: stap 6, afbeelding 1 van 2 Vtech Innotab 3 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Using a nylon or metal spudger, lift the blue plastic piece upwards.
    • Keeping the plastic piece lifted, carefully pinch the edge of the speaker and remove it.
    • Be sure not to tug on the speaker too violently to prevent tearing a wiring from its solder.
  7. Vtech Innotab 3 Speaker Replacement: stap 7, afbeelding 1 van 3 Vtech Innotab 3 Speaker Replacement: stap 7, afbeelding 2 van 3 Vtech Innotab 3 Speaker Replacement: stap 7, afbeelding 3 van 3
Conclusie
Zach Diviney
419 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 5-4, Panko Spring 2015 Lid van Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 607
