Inleiding
In order to replace the microphone grab yourself a PH00 screwdriver, a metal spudger, and a soldering kit.
- Before you begin disassembling the Vtech InnoTab 3, turn on your soldering iron. If working with others let them know that the soldering iron is on and to use caution.
Wat je nodig hebt
Slide the battery compartment door lock down.
While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
Carefully remove the batteries from the battery compartment.
Remove the four 7.6 mm screws using a PH00 screwdriver.
Lift up the circuit board from the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99
To replace the microphone, desolder the two connections that connect the speaker to the device.
This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
