Ga door naar hoofdinhoud
Vtech Innotab 3 Microphone Replacement
Wat je nodig hebt
  1. Vtech Innotab 3 Microphone Replacement, Rear Panel: stap 1, afbeelding 1 van 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: stap 1, afbeelding 2 van 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Microphone Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Microphone Replacement: stap 3, afbeelding 1 van 3 Vtech Innotab 3 Microphone Replacement: stap 3, afbeelding 2 van 3 Vtech Innotab 3 Microphone Replacement: stap 3, afbeelding 3 van 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Microphone Replacement: stap 4, afbeelding 1 van 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Microphone Replacement, Microphone: stap 5, afbeelding 1 van 3 Vtech Innotab 3 Microphone Replacement, Microphone: stap 5, afbeelding 2 van 3 Vtech Innotab 3 Microphone Replacement, Microphone: stap 5, afbeelding 3 van 3
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift up the circuit board from the device.
  6. Vtech Innotab 3 Microphone Replacement: stap 6, afbeelding 1 van 3 Vtech Innotab 3 Microphone Replacement: stap 6, afbeelding 2 van 3 Vtech Innotab 3 Microphone Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • To replace the microphone, desolder the two connections that connect the speaker to the device.
    • Use tweezers to keep the microphone steady as you desolder the connections.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
Conclusie
Zach Diviney
419 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 5-4, Panko Spring 2015 Lid van Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 346
