Inleiding
In order to replace jammed or broken buttons you will need a PH00 screwdriver and a metal spudger.
Wat je nodig hebt
Slide the battery compartment door lock down.
While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
Carefully remove the batteries from the battery compartment.
Remove the four 7.6 mm screws using a PH00 screwdriver.
Lift the circuit board up to give yourself room to remove the buttons.
