Ga door naar hoofdinhoud
Vtech InnoTab 3S Rear Panel Replacement
Wat je nodig hebt
  1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: stap 1, afbeelding 1 van 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: stap 1, afbeelding 2 van 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Rear Panel Replacement: stap 2, afbeelding 1 van 2 Vtech InnoTab 3S Rear Panel Replacement: stap 2, afbeelding 2 van 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Rear Panel Replacement: stap 3, afbeelding 1 van 3 Vtech InnoTab 3S Rear Panel Replacement: stap 3, afbeelding 2 van 3 Vtech InnoTab 3S Rear Panel Replacement: stap 3, afbeelding 3 van 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Rear Panel Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Karina Garcia
878 Reputatie
6 handleidingen geschreven
USF Tampa, Team 8-2, Eyestone Fall 2015 Lid van USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Leden
9 handleidingen geschreven
1Gids Commentaar
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 785
