Ga door naar hoofdinhoud
Vtech InnoTab 3S Headphone Port Replacement
Wat je nodig hebt
  1. Vtech InnoTab 3S Headphone Port Replacement, Rear Panel: stap 1, afbeelding 1 van 3 Vtech InnoTab 3S Headphone Port Replacement, Rear Panel: stap 1, afbeelding 2 van 3 Vtech InnoTab 3S Headphone Port Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Headphone Port Replacement: stap 2, afbeelding 1 van 2 Vtech InnoTab 3S Headphone Port Replacement: stap 2, afbeelding 2 van 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Headphone Port Replacement: stap 3, afbeelding 1 van 3 Vtech InnoTab 3S Headphone Port Replacement: stap 3, afbeelding 2 van 3 Vtech InnoTab 3S Headphone Port Replacement: stap 3, afbeelding 3 van 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Headphone Port Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Headphone Port Replacement, Headphone Port: stap 5, afbeelding 1 van 3 Vtech InnoTab 3S Headphone Port Replacement, Headphone Port: stap 5, afbeelding 2 van 3 Vtech InnoTab 3S Headphone Port Replacement, Headphone Port: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • The headphone port is located towards the top left side of the device.
    • With tweezers remove the headphone port from its slot on the device.
    • The headphone port is fastened by two plastic poles. For easier removal lift the headphone port perpendicular to the device upwards.
    • Avoid damaging the plastic poles fastening the headphone port to the device. They are extremely fragile.
    • Solder the wires securing the headphone port to the device.
    • Avoid forceful movements when soldering to prevent damage to device components and personal injury.
Conclusie
Karina Garcia
824 Reputatie
6 handleidingen geschreven
USF Tampa, Team 8-2, Eyestone Fall 2015 Lid van USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 197
