Ga door naar hoofdinhoud
Vornado 133 Compact Air Circulator Fuse Replacement
Wat je nodig hebt
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: stap 1, afbeelding 1 van 1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: stap 2, afbeelding 1 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 2, afbeelding 2 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 2, afbeelding 3 van 3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: stap 3, afbeelding 1 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 3, afbeelding 2 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
    very informative. A ok
    Richard Lovelace - Antwoord
    The information on the fuse is not useful. It needs to include the size, because the link to crapazon shows about 500 different sizes.
    hankthedog - Antwoord
Conclusie
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 andere personen hebben deze handleiding voltooid.
Erin Klein
483 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G2, Liner Summer 2017 Lid van UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 Leden
4 handleidingen geschreven
10Gids Commentaar
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Antwoord
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Antwoord
Fast-acting or slow-acting?
James Olsen - Antwoord
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Antwoord
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Antwoord
The fuse isnt clear glass its red strip white under what that mean
Lanier White - Antwoord
The fuse is not clear it has whitestrip with red strip what that
This plug ? has none those features
Dawn- M - Antwoord
I replaced the fuse and still will not turn on. Ive only had the fan for 6 months
Cheryl Richardson - Antwoord
Also wondering if the replacement fuse should be fast acting or slow acting?
Blixa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 121
Altijd: 33,781
