Ga door naar hoofdinhoud
Vizio SmartCast Crave 360 Speaker Ring Replacement
Wat je nodig hebt
  1. Vizio SmartCast Crave 360 Speaker Ring Replacement, Speaker Ring: stap 1, afbeelding 1 van 1
    • Place the speaker so that the speaker volume ring faces up.
  2. Vizio SmartCast Crave 360 Speaker Ring Replacement: stap 2, afbeelding 1 van 2 Vizio SmartCast Crave 360 Speaker Ring Replacement: stap 2, afbeelding 2 van 2
    • Using the halberd spudger, pop off the metal disc that is connected to the speaker ring.
    • Remove the metal disc.
    • Ignore the small circuit board that is under the metal disc. It is not important for this replacement.
  3. Vizio SmartCast Crave 360 Speaker Ring Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 5mm screws that connect the inner bearing to the outer ring using a Phillips #000 screwdriver.
  4. Vizio SmartCast Crave 360 Speaker Ring Replacement: stap 4, afbeelding 1 van 2 Vizio SmartCast Crave 360 Speaker Ring Replacement: stap 4, afbeelding 2 van 2
    • Take the outer ring and inner bearing off of the speaker.
    • Remove the outer ring from the inner bearing and plastic disc.
  5. Vizio SmartCast Crave 360 Speaker Ring Replacement: stap 5, afbeelding 1 van 1
    • Remove the inner bearing from the plastic disc so that all three components of the speaker ring are separated.
Conclusie
Pavani Lopez Leon
427 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 263
