Ga door naar hoofdinhoud
Vizio SmartCast Crave 360 Battery Replacement
Wat je nodig hebt
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: stap 3, afbeelding 1 van 2 Vizio SmartCast Crave 360 Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: stap 4, afbeelding 1 van 2 Vizio SmartCast Crave 360 Battery Replacement, Bass: stap 4, afbeelding 2 van 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: stap 5, afbeelding 1 van 3 Vizio SmartCast Crave 360 Battery Replacement: stap 5, afbeelding 2 van 3 Vizio SmartCast Crave 360 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: stap 6, afbeelding 1 van 2 Vizio SmartCast Crave 360 Battery Replacement, Battery: stap 6, afbeelding 2 van 2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: stap 7, afbeelding 1 van 1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: stap 8, afbeelding 1 van 2 Vizio SmartCast Crave 360 Battery Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: stap 9, afbeelding 1 van 2 Vizio SmartCast Crave 360 Battery Replacement: stap 9, afbeelding 2 van 2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: stap 10, afbeelding 1 van 1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: stap 11, afbeelding 1 van 1
    • Remove the motherboard from the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Pavani Lopez Leon
427 Reputatie
3 handleidingen geschreven
Één opmerking
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 60
Altijd: 955
