Ga door naar hoofdinhoud
Vizio SmartCast Crave 360 Bass Replacement
Wat je nodig hebt
  1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Bass Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Bass Replacement: stap 3, afbeelding 1 van 2 Vizio SmartCast Crave 360 Bass Replacement: stap 3, afbeelding 2 van 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Bass Replacement, Bass: stap 4, afbeelding 1 van 2 Vizio SmartCast Crave 360 Bass Replacement, Bass: stap 4, afbeelding 2 van 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Bass Replacement: stap 5, afbeelding 1 van 3 Vizio SmartCast Crave 360 Bass Replacement: stap 5, afbeelding 2 van 3 Vizio SmartCast Crave 360 Bass Replacement: stap 5, afbeelding 3 van 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Pavani Lopez Leon
424 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 408
