Ga door naar hoofdinhoud
Vizio CT15 Battery Replacement
Wat je nodig hebt
  1. Vizio CT15 Battery Replacement, Vizio CT15 Back Panel Removal: stap 1, afbeelding 1 van 2 Vizio CT15 Battery Replacement, Vizio CT15 Back Panel Removal: stap 1, afbeelding 2 van 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
    Vraag FixBot
    Voeg opmerking toe
  2. Vizio CT15 Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  3. Vizio CT15 Battery Replacement: stap 3, afbeelding 1 van 2 Vizio CT15 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
1Gids Commentaar
In case anyone comes across this page looking for the CMOS Battery, it is an ML1220 Battery. I found a comparable replacement of "LeFix ML1220 Rechargeable CMOS Battery Replacement Compatible with ASUS EEE PC 1101HA 1005HA T101MT 1101HAB 1005P,Acer Aspire 5920 5920G 5920 G Series,Fujitsu Amilo Pi 3560 3660 LI3710 LI3910" on Amazon (https://www.amazon.com/LeFix-Rechargeabl...)
Image: https://photos.app.goo.gl/hcaVn8TJUCFbXr...
Image: https://photos.app.goo.gl/ubCpmQMT4Rb5h1...
tech2life - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 1,591
