Ga door naar hoofdinhoud
Visual Land Prestige Pro 7D Reset Button Replacement
Wat je nodig hebt
  1. Visual Land Prestige Pro 7D Reset Button Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Reset Button Replacement: stap 2, afbeelding 1 van 1
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: stap 3, afbeelding 1 van 2 Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to lift the grey connector, located next to the reset button, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
    • Although not necessary for replacing the reset button, it is highly recommended to disconnect the ribbon. This ensures it will not get damaged during desoldering.
  4. Visual Land Prestige Pro 7D Reset Button Replacement: stap 4, afbeelding 1 van 3 Visual Land Prestige Pro 7D Reset Button Replacement: stap 4, afbeelding 2 van 3 Visual Land Prestige Pro 7D Reset Button Replacement: stap 4, afbeelding 3 van 3
    • Soldering guns are hot and can easily damage the device.
    • Desolder the four side dots holding the reset button in place.
    • If this is your first time desoldering, here is a helpful guide to show you Hoe moet je (de-)solderen?.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jennifer Laybourn
353 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-41, Amido Fall 2014 Lid van Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 3,724
