Inleiding
Before starting this guide its important to note that the battery replacement requires soldering. Don't know how to solder? Don't worry! You can learn how right here.
Wat je nodig hebt
Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use wide tip tweezers to gently remove the three pieces of tape attached to battery.
Once the tape has been removed, the battery will be free from the tablet except for the wired connections to the circuit board.
Mark where the positive (red) and negative (black) wires are on the circuit board.
Before disconnecting battery, review Soldering Tips to ensure proper soldering.
Use soldering iron to remove +(red) battery lead.
Remove the -(black) battery lead.
