Inleiding
This guide shows how to remove the Visioneer OneTouch 7400 USB motherboard for repair or replacement.
WARNING: Circuitry will be exposed. Handle the motherboard carefully in order to avoid damage to the equipment and yourself. Keep the equipment away from heat sources and water.
Wat je nodig hebt
On the bottom half of the casing, remove the two screws in the motherboard.
