Ga door naar hoofdinhoud
Visioneer OneTouch 7400 USB Belt Replacement
Wat je nodig hebt
    1. Visioneer OneTouch 7400 USB Belt Replacement, Outer Case: stap 1, afbeelding 1 van 1
      • On the bottom of the scanner, remove the screw at the top left side.
      Vraag FixBot
      Voeg opmerking toe
    2. Visioneer OneTouch 7400 USB Belt Replacement: stap 2, afbeelding 1 van 2 Visioneer OneTouch 7400 USB Belt Replacement: stap 2, afbeelding 2 van 2
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      Vraag FixBot
      Voeg opmerking toe
    3. Visioneer OneTouch 7400 USB Belt Replacement: stap 3, afbeelding 1 van 3 Visioneer OneTouch 7400 USB Belt Replacement: stap 3, afbeelding 2 van 3 Visioneer OneTouch 7400 USB Belt Replacement: stap 3, afbeelding 3 van 3
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      Vraag FixBot
      Voeg opmerking toe
    4. Visioneer OneTouch 7400 USB Belt Replacement: stap 4, afbeelding 1 van 1
      • Separate the two casement pieces.
      Vraag FixBot
      Voeg opmerking toe
    1. Visioneer OneTouch 7400 USB Belt Replacement, Belt: stap 5, afbeelding 1 van 1
      • Remove the screw holding the tension spring in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Visioneer OneTouch 7400 USB Belt Replacement: stap 6, afbeelding 1 van 1
      • Use the plastic opening tool to lift up the tension spring.
      • Be careful. The spring will fly.
      Vraag FixBot
      Voeg opmerking toe
    3. Visioneer OneTouch 7400 USB Belt Replacement: stap 7, afbeelding 1 van 1
      • Remove the belt from the spool.
      • The spool is a loose piece; don't lose it.
      Vraag FixBot
      Voeg opmerking toe
    4. Visioneer OneTouch 7400 USB Belt Replacement: stap 8, afbeelding 1 van 1
      • Loosen the belt enough to turn over the sensor bar.
      Vraag FixBot
      Voeg opmerking toe
    5. Visioneer OneTouch 7400 USB Belt Replacement: stap 9, afbeelding 1 van 2 Visioneer OneTouch 7400 USB Belt Replacement: stap 9, afbeelding 2 van 2
      • With the sensor bar turned upside down, remove the screw in the middle of the bar.
      • Lift off the metal plate if it does not come away with the screw.
      Vraag FixBot
      Voeg opmerking toe
    6. Visioneer OneTouch 7400 USB Belt Replacement: stap 10, afbeelding 1 van 1
      • Carefully lift the belt out of the groove in the sensor bar to remove.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jena
608 Reputatie
6 handleidingen geschreven
University of Maine, Team 1-13, Diaz Fall 2013 Lid van University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
3 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 605
