Ga door naar hoofdinhoud
Verizon Wireless CDM 7075 Keypad Replacement
Wat je nodig hebt
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: stap 1, afbeelding 1 van 2 Verizon Wireless CDM 7075 Keypad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
    Vraag FixBot
    Voeg opmerking toe
  2. Verizon Wireless CDM 7075 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the battery from the phone by prying the battery from the top.
    Vraag FixBot
    Voeg opmerking toe
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: stap 3, afbeelding 1 van 1
    • Pry off the top cover on the back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Verizon Wireless CDM 7075 Keypad Replacement: stap 4, afbeelding 1 van 1
    • You will then remove the screws from the back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Verizon Wireless CDM 7075 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
    Vraag FixBot
    Voeg opmerking toe
  6. Verizon Wireless CDM 7075 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
    Vraag FixBot
    Voeg opmerking toe
  7. Verizon Wireless CDM 7075 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Corey Ryman
255 Reputatie
4 handleidingen geschreven
James Madison, Team 2-4, Allen Fall 2011 Lid van James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 1,500
