Inleiding
What you can expect from this guide is a step by step process on how to remove the LCD display screen on a Verizon Ellipsis Jetpack MHS800L.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
Gereedschap gebruikt in deze stap:iFixit Opening Picks (Set of 6)$4.95
Use a plastic pick at the seams and pry open the case.
Once you have the case off of your device gently pull your battery away from the device.
Locate the LCD screen cable and unlatch the harness connection form the circuit board.
Één andere persoon heeft deze handleiding voltooid.
