Ga door naar hoofdinhoud
Verizon Ellipsis 8 Button Replacement
Wat je nodig hebt
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: stap 1, afbeelding 1 van 1
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
    Vraag FixBot
    Voeg opmerking toe
  2. Verizon Ellipsis 8  Button Replacement: stap 2, afbeelding 1 van 1
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
    Vraag FixBot
    Voeg opmerking toe
  3. Verizon Ellipsis 8  Button Replacement: stap 3, afbeelding 1 van 1
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jack
610 Reputatie
3 handleidingen geschreven
UC Davis, Team S18-G6, Lore Winter 2019 Lid van UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 Leden
1Gids Commentaar
where can i purchase replacement buttons for this device? anyone know? Thanks!!!
Broadcast Depth - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 35
Altijd: 782
