Ga door naar hoofdinhoud
Verizon Ellipsis 10 Battery Replacement
Wat je nodig hebt
  1. Verizon Ellipsis 10 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Open the SD/SIM card cover to start prying off the back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Verizon Ellipsis 10 Battery Replacement: stap 2, afbeelding 1 van 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
    Vraag FixBot
    Voeg opmerking toe
  3. Verizon Ellipsis 10 Battery Replacement: stap 3, afbeelding 1 van 1
    • Follow along the edge of the device to undo all of the retaining clips.
    Vraag FixBot
    Voeg opmerking toe
  4. Verizon Ellipsis 10 Battery Replacement: stap 4, afbeelding 1 van 1
    • Once all the clips are undone, the back panel should come off with little effort.
    Vraag FixBot
    Voeg opmerking toe
  5. Verizon Ellipsis 10 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
    Vraag FixBot
    Voeg opmerking toe
  6. Verizon Ellipsis 10 Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the top piece of tape using an iFixit opening tool.
    Vraag FixBot
    Voeg opmerking toe
  7. Verizon Ellipsis 10 Battery Replacement: stap 7, afbeelding 1 van 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
    Vraag FixBot
    Voeg opmerking toe
  8. Verizon Ellipsis 10 Battery Replacement: stap 8, afbeelding 1 van 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
    Vraag FixBot
    Voeg opmerking toe
  9. Verizon Ellipsis 10 Battery Replacement: stap 9, afbeelding 1 van 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
3 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Has anyone found a source for these batteries?
brianmjones - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 2,244
