Ga door naar hoofdinhoud
VTech VM3254 Monitor Speaker Replacement
Wat je nodig hebt
  1. VTech VM3254 Monitor Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 VTech VM3254 Monitor Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Speaker Replacement: stap 2, afbeelding 1 van 3 VTech VM3254 Monitor Speaker Replacement: stap 2, afbeelding 2 van 3 VTech VM3254 Monitor Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Speaker Replacement: stap 3, afbeelding 1 van 2 VTech VM3254 Monitor Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Speaker Replacement: stap 4, afbeelding 1 van 3 VTech VM3254 Monitor Speaker Replacement: stap 4, afbeelding 2 van 3 VTech VM3254 Monitor Speaker Replacement: stap 4, afbeelding 3 van 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
  5. VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: stap 5, afbeelding 1 van 2 VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: stap 5, afbeelding 2 van 2
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Speaker Replacement: stap 6, afbeelding 1 van 1
    • Desolder the wire connecting the speaker to the board.
Conclusie
Travis Gunter
135 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 235
