Ga door naar hoofdinhoud
VTech Kidizoom Camera Connect Shutter Button Replacement
Wat je nodig hebt
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: stap 1, afbeelding 1 van 2 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: stap 1, afbeelding 2 van 2
      • Remove batteries and SD card before beginning disassembly!
      • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: stap 2, afbeelding 1 van 2 VTech Kidizoom Camera Connect Shutter Button Replacement: stap 2, afbeelding 2 van 2
      • Remove all four (11mm) screws with the Philips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: stap 3, afbeelding 1 van 3 VTech Kidizoom Camera Connect Shutter Button Replacement: stap 3, afbeelding 2 van 3 VTech Kidizoom Camera Connect Shutter Button Replacement: stap 3, afbeelding 3 van 3
      • Remove the two battery cartridges located on the underside of the camera.
      • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. VTech Kidizoom Camera Connect Shutter Button Replacement: stap 4, afbeelding 1 van 1
      • Beware of the two black viewfinder lens falling out as you pry open the device!
      • The device should now be open and ready for further repair and/or replacement parts.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: stap 5, afbeelding 1 van 1
      • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: stap 6, afbeelding 1 van 1
      • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: stap 7, afbeelding 1 van 2 VTech Kidizoom Camera Connect Shutter Button Replacement: stap 7, afbeelding 2 van 2
      • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin Sanchez
544 Reputatie
4 handleidingen geschreven
USF Tampa, Team 6-4, Eyestone Spring 2016 Lid van USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 1,617
