Ga door naar hoofdinhoud
VTech Kidizoom Action Cam LCD Screen Replacement
Wat je nodig hebt
    1. VTech Kidizoom Action Cam LCD Screen Replacement, Display Assembly: stap 1, afbeelding 1 van 1
      • Make sure that the master power switch is set to the (O) position.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Kidizoom Action Cam LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Using a plastic opening tool, gently pry off the circular plating over the camera lens.
      • The circular plating is held by a mild adhesive. It will not be necessary to replace this adhesive during the reassembly process.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Kidizoom Action Cam LCD Screen Replacement: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Magnetic Project Mat
      $19.95
      • Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
      • Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
      • As there will be many screws being removed from the device, we recommend using a magnetic device such as the iFixit Magnetic Project Mat.
      Vraag FixBot
      Voeg opmerking toe
    4. VTech Kidizoom Action Cam LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Pry off the transparent plating and paper design using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. VTech Kidizoom Action Cam LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. VTech Kidizoom Action Cam LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
      Vraag FixBot
      Voeg opmerking toe
    7. VTech Kidizoom Action Cam LCD Screen Replacement: stap 7, afbeelding 1 van 3 VTech Kidizoom Action Cam LCD Screen Replacement: stap 7, afbeelding 2 van 3 VTech Kidizoom Action Cam LCD Screen Replacement: stap 7, afbeelding 3 van 3
      • Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
      • Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech Kidizoom Action Cam LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 3 VTech Kidizoom Action Cam LCD Screen Replacement, LCD Screen: stap 8, afbeelding 2 van 3 VTech Kidizoom Action Cam LCD Screen Replacement, LCD Screen: stap 8, afbeelding 3 van 3
      • Heat the iOpener tool, then press the iOpener tool onto the connectors to heat the glue on the connector ribbon.
      • If the iOpener tool is not available, use a hair dryer to heat the glue on the connector ribbon and then use a Q-tip dabbed in Isopropyl alcohol to dab the heated glue.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Kidizoom Action Cam LCD Screen Replacement: stap 9, afbeelding 1 van 1
      • Gently peel the connector ribbon being held down by the heated glue until it is completely removed.
      • Be cautious of very hot glue when peeling the connector ribbon off of the motherboard
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Anthony Teresi
713 Reputatie
4 handleidingen geschreven
USF Tampa, Team 3-5, Sullivan Spring 2016 Lid van USF Tampa, Team 3-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G5
3 Leden
26 handleidingen geschreven
1Gids Commentaar
Where do I find a new LCD screen replacement part?
Abbie - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 48
Altijd: 4,222
