Ga door naar hoofdinhoud
VTech InnoTab Max Camera Replacement
Wat je nodig hebt
    1. VTech InnoTab Max Camera Replacement, Cover: stap 1, afbeelding 1 van 3 VTech InnoTab Max Camera Replacement, Cover: stap 1, afbeelding 2 van 3 VTech InnoTab Max Camera Replacement, Cover: stap 1, afbeelding 3 van 3
      • Remove all screw caps from the back panel using a metal spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech InnoTab Max Camera Replacement: stap 2, afbeelding 1 van 3 VTech InnoTab Max Camera Replacement: stap 2, afbeelding 2 van 3 VTech InnoTab Max Camera Replacement: stap 2, afbeelding 3 van 3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech InnoTab Max Camera Replacement: stap 3, afbeelding 1 van 2 VTech InnoTab Max Camera Replacement: stap 3, afbeelding 2 van 2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. VTech InnoTab Max Camera Replacement: stap 4, afbeelding 1 van 2 VTech InnoTab Max Camera Replacement: stap 4, afbeelding 2 van 2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech InnoTab Max Camera Replacement, Camera: stap 5, afbeelding 1 van 1
      • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech InnoTab Max Camera Replacement: stap 6, afbeelding 1 van 2 VTech InnoTab Max Camera Replacement: stap 6, afbeelding 2 van 2
      • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
      • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech InnoTab Max Camera Replacement: stap 7, afbeelding 1 van 1
      • The camera is now removed completely removed from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Schioppo
594 Reputatie
4 handleidingen geschreven
USF Tampa, Team S5-G5, Lacy Spring 2017 Lid van USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 858
