Ga door naar hoofdinhoud
VTech InnoTab 2S Motherboard Removal
Wat je nodig hebt
  1. VTech InnoTab 2S Motherboard Removal, Back Panel: stap 1, afbeelding 1 van 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Motherboard Removal: stap 2, afbeelding 1 van 2 VTech InnoTab 2S Motherboard Removal: stap 2, afbeelding 2 van 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Motherboard Removal: stap 3, afbeelding 1 van 3 VTech InnoTab 2S Motherboard Removal: stap 3, afbeelding 2 van 3 VTech InnoTab 2S Motherboard Removal: stap 3, afbeelding 3 van 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Motherboard Removal: stap 4, afbeelding 1 van 2 VTech InnoTab 2S Motherboard Removal: stap 4, afbeelding 2 van 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Motherboard Removal: stap 5, afbeelding 1 van 2 VTech InnoTab 2S Motherboard Removal: stap 5, afbeelding 2 van 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Motherboard Removal, Motherboard: stap 6, afbeelding 1 van 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Motherboard Removal: stap 7, afbeelding 1 van 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Motherboard Removal: stap 8, afbeelding 1 van 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Motherboard Removal: stap 9, afbeelding 1 van 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Motherboard Removal: stap 10, afbeelding 1 van 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
Eindstreep
Ricardo Espinosa
221 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-1, Lacy Fall 2016 Lid van USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 370
