Ga door naar hoofdinhoud
VTech InnoTab 2S Headphone Jack Replacement
Wat je nodig hebt
  1. VTech InnoTab 2S Headphone Jack Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Headphone Jack Replacement: stap 2, afbeelding 1 van 2 VTech InnoTab 2S Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Headphone Jack Replacement: stap 3, afbeelding 1 van 3 VTech InnoTab 2S Headphone Jack Replacement: stap 3, afbeelding 2 van 3 VTech InnoTab 2S Headphone Jack Replacement: stap 3, afbeelding 3 van 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Headphone Jack Replacement: stap 4, afbeelding 1 van 2 VTech InnoTab 2S Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Headphone Jack Replacement: stap 5, afbeelding 1 van 2 VTech InnoTab 2S Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Headphone Jack Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Headphone Jack Replacement: stap 10, afbeelding 1 van 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2S Headphone Jack Replacement, Headphone Jack: stap 11, afbeelding 1 van 1
    • First use the solderer tool to desolder the two points boxed in red on the image.
  12. VTech InnoTab 2S Headphone Jack Replacement: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Flip over the circuit board.
    • Using the metal tweezers, firmly grasp the headphone jack on either side and pull up to remove.
Conclusie
Esthevan Romeiro
261 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-1, Lacy Fall 2016 Lid van USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 173
