Ga door naar hoofdinhoud
VTech InnoTab 2 Camera Replacement
Wat je nodig hebt
    1. VTech InnoTab 2 Camera Replacement, Battery: stap 1, afbeelding 1 van 3 VTech InnoTab 2 Camera Replacement, Battery: stap 1, afbeelding 2 van 3 VTech InnoTab 2 Camera Replacement, Battery: stap 1, afbeelding 3 van 3
      • Apply slight pressure and slide the button above the battery cabinet to the right to open.
      • Remove battery cabinet cover by sliding away from the center of device.
      • This device requires 4AA batteries to function without the AC adaptor.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech InnoTab 2 Camera Replacement, Back Panel: stap 2, afbeelding 1 van 3 VTech InnoTab 2 Camera Replacement, Back Panel: stap 2, afbeelding 2 van 3 VTech InnoTab 2 Camera Replacement, Back Panel: stap 2, afbeelding 3 van 3
      • Remove all nine plastic caps from the back of the device using the plastic opening tool.
      • These covers are made of hard plastic so they may be difficult to remove.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech InnoTab 2 Camera Replacement: stap 3, afbeelding 1 van 3 VTech InnoTab 2 Camera Replacement: stap 3, afbeelding 2 van 3 VTech InnoTab 2 Camera Replacement: stap 3, afbeelding 3 van 3
      • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
      • Be careful not to apply excessive force.
      • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech InnoTab 2 Camera Replacement: stap 4, afbeelding 1 van 2 VTech InnoTab 2 Camera Replacement: stap 4, afbeelding 2 van 2
      • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
      • Do not use excessive force while removing the screws to prevent damaging the plastic case.
      Vraag FixBot
      Voeg opmerking toe
    4. VTech InnoTab 2 Camera Replacement: stap 5, afbeelding 1 van 2 VTech InnoTab 2 Camera Replacement: stap 5, afbeelding 2 van 2
      • Using the plastic opening tool, detach the back plate from the front piece.
      • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
      • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech InnoTab 2 Camera Replacement, Camera: stap 6, afbeelding 1 van 3 VTech InnoTab 2 Camera Replacement, Camera: stap 6, afbeelding 2 van 3 VTech InnoTab 2 Camera Replacement, Camera: stap 6, afbeelding 3 van 3
      • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
      • The connection to the camera is located on top side of the devices motherboard.
      • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
      • Attach the replacement camera and lower the latch until a click sound can be heard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Roberto Valdes
302 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G85, Cagle Fall 2017 Lid van USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 682
