Ga door naar hoofdinhoud
VTech InnoTab 2 Back Panel Replacement
Wat je nodig hebt
  1. VTech InnoTab 2 Back Panel Replacement, Battery: stap 1, afbeelding 1 van 3 VTech InnoTab 2 Back Panel Replacement, Battery: stap 1, afbeelding 2 van 3 VTech InnoTab 2 Back Panel Replacement, Battery: stap 1, afbeelding 3 van 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
    Vraag FixBot
    Voeg opmerking toe
  2. VTech InnoTab 2 Back Panel Replacement, Back Panel: stap 2, afbeelding 1 van 3 VTech InnoTab 2 Back Panel Replacement, Back Panel: stap 2, afbeelding 2 van 3 VTech InnoTab 2 Back Panel Replacement, Back Panel: stap 2, afbeelding 3 van 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
    Vraag FixBot
    Voeg opmerking toe
  3. VTech InnoTab 2 Back Panel Replacement: stap 3, afbeelding 1 van 3 VTech InnoTab 2 Back Panel Replacement: stap 3, afbeelding 2 van 3 VTech InnoTab 2 Back Panel Replacement: stap 3, afbeelding 3 van 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. VTech InnoTab 2 Back Panel Replacement: stap 4, afbeelding 1 van 2 VTech InnoTab 2 Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
    Vraag FixBot
    Voeg opmerking toe
  5. VTech InnoTab 2 Back Panel Replacement: stap 5, afbeelding 1 van 2 VTech InnoTab 2 Back Panel Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Roberto Valdes
302 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G85, Cagle Fall 2017 Lid van USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 741
