Ga door naar hoofdinhoud
VTech CS6719-2 Speaker Replacement
Wat je nodig hebt
  1. VTech CS6719-2 Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 VTech CS6719-2 Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: stap 5, afbeelding 1 van 2 VTech CS6719-2 Speaker Replacement, Circuit Board: stap 5, afbeelding 2 van 2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: stap 7, afbeelding 1 van 2 VTech CS6719-2 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Refer to How To Solder and Desolder Connections Hoe moet je (de-)solderen?
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very ho
Conclusie
Benjamin Field
270 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-4, Baechle Spring 2016 Lid van IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Leden
16 handleidingen geschreven
2Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 1,051
