Ga door naar hoofdinhoud
VTech Baby's Learning Laptop Mode Switch Replacement
Wat je nodig hebt
    1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: stap 1, afbeelding 1 van 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Baby's Learning Laptop Mode Switch Replacement: stap 2, afbeelding 1 van 1
      • Remove the battery door.
      • Take out the batteries.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Baby's Learning Laptop Mode Switch Replacement: stap 3, afbeelding 1 van 1
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Vraag FixBot
      Voeg opmerking toe
    4. VTech Baby's Learning Laptop Mode Switch Replacement: stap 4, afbeelding 1 van 2 VTech Baby's Learning Laptop Mode Switch Replacement: stap 4, afbeelding 2 van 2
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: stap 5, afbeelding 1 van 2 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: stap 5, afbeelding 2 van 2
      • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Baby's Learning Laptop Mode Switch Replacement: stap 6, afbeelding 1 van 3 VTech Baby's Learning Laptop Mode Switch Replacement: stap 6, afbeelding 2 van 3 VTech Baby's Learning Laptop Mode Switch Replacement: stap 6, afbeelding 3 van 3
      • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
      • Lay the board down gently and out of the way.
      • Take care not to damage any of the wires or the board itself.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Baby's Learning Laptop Mode Switch Replacement: stap 7, afbeelding 1 van 1
      • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
      • Five 7.3mm
      • Two 6.0mm
      Vraag FixBot
      Voeg opmerking toe
    4. VTech Baby's Learning Laptop Mode Switch Replacement: stap 8, afbeelding 1 van 1
      • Once the screws have been removed, the mode switch assembly can be removed easily.
      • Take care not to misplace the spring indicated in the picture.
      • You need this spring to find a matching replacement if it is in anyway damaged.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Scott Parkinson
113 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-2, Blackwell Fall 2015 Lid van USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 834
