Inleiding
Do any of the lights on your device appear to be dimly lit or not come on at all? Replacing the LEDs may solve your problem.
Wat je nodig hebt
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Pickup the array by the opening in the center of the board.
Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
Bijna klaar!
Conclusie
