Inleiding
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
Wat je nodig hebt
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Gereedschap gebruikt in deze stap:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Below the logic board, the small black microphone is resting within the case.
Één andere persoon heeft deze handleiding voltooid.
