Ga door naar hoofdinhoud
Using a Floor Jack
Wat je nodig hebt
    1. Using a Floor Jack, Using a Floor Jack: stap 1, afbeelding 1 van 2 Using a Floor Jack, Using a Floor Jack: stap 1, afbeelding 2 van 2
      • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
      • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
      • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
      Vraag FixBot
      Voeg opmerking toe
    2. Using a Floor Jack, Using floor jack to lift car.: stap 2, afbeelding 1 van 1
      • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
      Vraag FixBot
      Voeg opmerking toe
    3. Using a Floor Jack: stap 3, afbeelding 1 van 1
      • Place the jack stand under the jack mounting point.
      • The jack mounting point is a metallic protrusion beneath each of the car doors.
      Vraag FixBot
      Voeg opmerking toe
    4. Using a Floor Jack: stap 4, afbeelding 1 van 1
      • Raise the jack stand until it contacts the jack mounting point.
      • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Shaun MacDonald
2.654 Reputatie
8 handleidingen geschreven
Cal Poly, Team 24-27, Regan Fall 2012 Lid van Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Leden
58 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 226
Altijd: 44,302
