Ga door naar hoofdinhoud
Unnecto Drone M Digitizer Replacement
Wat je nodig hebt
    1. Unnecto Drone M Digitizer Replacement, Unnecto Drone M Disassembly: stap 1, afbeelding 1 van 2 Unnecto Drone M Digitizer Replacement, Unnecto Drone M Disassembly: stap 1, afbeelding 2 van 2
      • Place the phone facedown on a cleared work area
      • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Unnecto Drone M Digitizer Replacement: stap 2, afbeelding 1 van 1
      • Grip the top right corner of the battery.
      • Remove the battery by pulling it outwards.
      Vraag FixBot
      Voeg opmerking toe
    3. Unnecto Drone M Digitizer Replacement: stap 3, afbeelding 1 van 1
      • Remove the four screws on the back of the phone using a Philips 000 screwdriver
      Vraag FixBot
      Voeg opmerking toe
    4. Unnecto Drone M Digitizer Replacement: stap 4, afbeelding 1 van 1
      • Separate the frame evenly using a plastic opening tool.
      • Be careful, as the frame is thin and can break easily.
      Vraag FixBot
      Voeg opmerking toe
    5. Unnecto Drone M Digitizer Replacement: stap 5, afbeelding 1 van 2 Unnecto Drone M Digitizer Replacement: stap 5, afbeelding 2 van 2
      • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Unnecto Drone M Digitizer Replacement: stap 6, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
      Vraag FixBot
      Voeg opmerking toe
    7. Unnecto Drone M Digitizer Replacement: stap 7, afbeelding 1 van 1
      • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
      • The white circuit is flimsy and securely glued to the frame.
      Vraag FixBot
      Voeg opmerking toe
    8. Unnecto Drone M Digitizer Replacement: stap 8, afbeelding 1 van 2 Unnecto Drone M Digitizer Replacement: stap 8, afbeelding 2 van 2
      • Set aside the circuit board from the screen protector.
      Vraag FixBot
      Voeg opmerking toe
    1. Unnecto Drone M Digitizer Replacement, Digitizer: stap 9, afbeelding 1 van 2 Unnecto Drone M Digitizer Replacement, Digitizer: stap 9, afbeelding 2 van 2
      • Replace the old plastic screen with the new one.
      • Reassemble the phone by following the steps in reverse order.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 548
