Ga door naar hoofdinhoud
Uniden Dect 6.0 Display Replacement
Wat je nodig hebt
  1. Uniden Dect 6.0 Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: stap 2, afbeelding 1 van 1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: stap 3, afbeelding 1 van 1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: stap 4, afbeelding 1 van 2 Uniden Dect 6.0 Display Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: stap 7, afbeelding 1 van 1
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: stap 8, afbeelding 1 van 1
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Megan Lawrence
534 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 6,965
