Ga door naar hoofdinhoud
Unbranded UB-15MS10 Battery Replacement
Wat je nodig hebt
    1. Unbranded UB-15MS10 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use an opening tool to pry off the lid of the memory card compartment.
      Vraag FixBot
      Voeg opmerking toe
    2. Unbranded UB-15MS10 Battery Replacement: stap 2, afbeelding 1 van 1
      • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Unbranded UB-15MS10 Battery Replacement: stap 3, afbeelding 1 van 2 Unbranded UB-15MS10 Battery Replacement: stap 3, afbeelding 2 van 2
      • Insert opening tools to partially pry open the cover.
      Vraag FixBot
      Voeg opmerking toe
    4. Unbranded UB-15MS10 Battery Replacement: stap 4, afbeelding 1 van 1
      • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Unbranded UB-15MS10 Battery Replacement: stap 5, afbeelding 1 van 1
      • Remove the tape that is holding the battery in place.
      Vraag FixBot
      Voeg opmerking toe
    6. Unbranded UB-15MS10 Battery Replacement: stap 6, afbeelding 1 van 1
      • Cut the wires connecting the battery to the device using a pair of wire cutters.
      Vraag FixBot
      Voeg opmerking toe
    7. Unbranded UB-15MS10 Battery Replacement: stap 7, afbeelding 1 van 1
      • Carefully remove the battery, making sure that all wires are disconnected.
      Vraag FixBot
      Voeg opmerking toe
    8. Unbranded UB-15MS10 Battery Replacement: stap 8, afbeelding 1 van 1
      • Splice the new battery with the red, white, and black wires connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow directions 1-7 in reverse order.
4 andere personen hebben deze handleiding voltooid.
Evan Peterson
338 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G5
3 Leden
4 handleidingen geschreven
1Gids Commentaar
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 2,922
