Ga door naar hoofdinhoud
UTStarcom CDM8945vw Speaker Replacement
Wat je nodig hebt
    1. UTStarcom CDM8945vw Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
      • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
      Vraag FixBot
      Voeg opmerking toe
    2. UTStarcom CDM8945vw Speaker Replacement: stap 2, afbeelding 1 van 1
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. UTStarcom CDM8945vw Speaker Replacement, Antenna: stap 3, afbeelding 1 van 1
      • Identify the antenna. It is the extendable plastic component pictured here.
      Vraag FixBot
      Voeg opmerking toe
    2. UTStarcom CDM8945vw Speaker Replacement: stap 4, afbeelding 1 van 1
      • Twist the base in a counter-clockwise motion to unscrew the antenna.
      Vraag FixBot
      Voeg opmerking toe
    3. UTStarcom CDM8945vw Speaker Replacement: stap 5, afbeelding 1 van 2 UTStarcom CDM8945vw Speaker Replacement: stap 5, afbeelding 2 van 2
      • The antenna should slide right out of the phone when finished.
      Vraag FixBot
      Voeg opmerking toe
    1. UTStarcom CDM8945vw Speaker Replacement, Speaker: stap 6, afbeelding 1 van 1
      • Remove the small rubber grommet using the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. UTStarcom CDM8945vw Speaker Replacement: stap 7, afbeelding 1 van 1
      • Remove five screws using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. UTStarcom CDM8945vw Speaker Replacement: stap 8, afbeelding 1 van 1
      • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
      • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
      Vraag FixBot
      Voeg opmerking toe
    4. UTStarcom CDM8945vw Speaker Replacement: stap 9, afbeelding 1 van 1
      • Remove the back piece of the outer case.
      Vraag FixBot
      Voeg opmerking toe
    5. UTStarcom CDM8945vw Speaker Replacement: stap 10, afbeelding 1 van 1
      • Remove the speaker using a plastic opening tool.
      • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. UTStarcom CDM8945vw Speaker Replacement: stap 11, afbeelding 1 van 2 UTStarcom CDM8945vw Speaker Replacement: stap 11, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the wire attached to the speaker from the motherboard using tweezers.
      • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Eli
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-26, Regan Fall 2012 Lid van Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Leden
35 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 609
