Ga door naar hoofdinhoud
USB 1020 Water Pump of DC 3.5-9V Replacement
Wat je nodig hebt
  1. USB 1020 Water Pump of DC 3.5-9V Replacement, USB 1020 Water Pump of DC 3.5-9V: stap 1, afbeelding 1 van 2 USB 1020 Water Pump of DC 3.5-9V Replacement, USB 1020 Water Pump of DC 3.5-9V: stap 1, afbeelding 2 van 2
    • Unplug the USB-C cord from the fountain.
    • Only proceed with dry hands to prevent being electrocuted.
  2. USB 1020 Water Pump of DC 3.5-9V Replacement: stap 2, afbeelding 1 van 3 USB 1020 Water Pump of DC 3.5-9V Replacement: stap 2, afbeelding 2 van 3 USB 1020 Water Pump of DC 3.5-9V Replacement: stap 2, afbeelding 3 van 3
    • Carefully pull out the water pump by pulling the wire from the reservoir located at the back.
  3. USB 1020 Water Pump of DC 3.5-9V Replacement: stap 3, afbeelding 1 van 2 USB 1020 Water Pump of DC 3.5-9V Replacement: stap 3, afbeelding 2 van 2
    • Detach the old water pump from the tube by gently pulling on the pump.
  4. USB 1020 Water Pump of DC 3.5-9V Replacement: stap 4, afbeelding 1 van 1
    • Adjust the water pressure and flow on the new water pump.
    • Shift switch to the right to lower the pressure and left to increase the pressure.
  5. USB 1020 Water Pump of DC 3.5-9V Replacement: stap 5, afbeelding 1 van 3 USB 1020 Water Pump of DC 3.5-9V Replacement: stap 5, afbeelding 2 van 3 USB 1020 Water Pump of DC 3.5-9V Replacement: stap 5, afbeelding 3 van 3
    • Connect the new water pump to the tube.
    • Make sure you hear a click sound to ensure the connection is secure.
  6. USB 1020 Water Pump of DC 3.5-9V Replacement: stap 6, afbeelding 1 van 1
    • Place the new water pump into the reservoir.
  7. USB 1020 Water Pump of DC 3.5-9V Replacement: stap 7, afbeelding 1 van 2 USB 1020 Water Pump of DC 3.5-9V Replacement: stap 7, afbeelding 2 van 2
    • Plug in the USB-C cord to turn on the fountain.
    • Use dry hands to prevent being electrocuted.
Conclusie
With these easy-to-follow steps, you can seamlessly replace the water pump in your indoor fountain to keep it in excellent working condition.
Guneet Longia
159 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 122
