Ga door naar hoofdinhoud
Turtle Beach Recon Cloud Battery Replacement
Wat je nodig hebt
  1. Turtle Beach Recon Cloud Battery Replacement, Back Casing: stap 1, afbeelding 1 van 2 Turtle Beach Recon Cloud Battery Replacement, Back Casing: stap 1, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
    • The 2 inner screws are hidden under the Turtle Beach sticker.
    • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
    Vraag FixBot
  2. Turtle Beach Recon Cloud Battery Replacement: stap 2, afbeelding 1 van 2 Turtle Beach Recon Cloud Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
    • Do the same to the other inner grip.
    • Do not take off the outer grips as they have wiring attached to them.
    Vraag FixBot
  3. Turtle Beach Recon Cloud Battery Replacement: stap 3, afbeelding 1 van 2 Turtle Beach Recon Cloud Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift off the back casing.
    Vraag FixBot
  4. Turtle Beach Recon Cloud Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Turtle Beach Recon Cloud Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Turtle Beach Recon Cloud Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Insert a spudger between the controller and the battery pack.
    • Use the spudger to loosen the battery from the motherboard.
    • Gently lift the battery pack until just out so as to not pull on the wire attached.
    Vraag FixBot
  5. Turtle Beach Recon Cloud Battery Replacement: stap 5, afbeelding 1 van 1
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Don't pull on the wires as this can potentially damage the socket and device.
    Vraag FixBot
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alyssa Davis
521 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 95
