Inleiding
If you find that your microphone has broken after extensive use or damage, you may want to take the opportunity to replace it before buying a new headset. This guide will take you through the steps necessary to ensure that your microphone replaced and working again.
Wat je nodig hebt
Use a spudger to pry up the black plastic housing.
Remove the plastic cover.
Bijna klaar!
Conclusie
