Ga door naar hoofdinhoud
Turtle Beach Elite Pro Left Speaker Replacement
Wat je nodig hebt
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Ear Cushion: stap 1, afbeelding 1 van 1
      • Firmly pinch ear cushion between thumb and forefinger.
      • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
      • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
      Vraag FixBot
      Voeg opmerking toe
    2. Turtle Beach Elite Pro Left Speaker  Replacement: stap 2, afbeelding 1 van 2 Turtle Beach Elite Pro Left Speaker  Replacement: stap 2, afbeelding 2 van 2
      • Rotate ear cushion counter-clockwise about half an inch.
      • The ear cushion should audibly snap out of place.
      • After it has audibly snapped out of place, lift the ear cushion off of the device.
      • During reassembly, rotate the ear cushion clockwise.
      Vraag FixBot
      Voeg opmerking toe
    3. Turtle Beach Elite Pro Left Speaker  Replacement: stap 3, afbeelding 1 van 2 Turtle Beach Elite Pro Left Speaker  Replacement: stap 3, afbeelding 2 van 2
      • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
      • Make sure that both the ear cushion and the orange plate have the same designation.
      • Once the pegs are aligned, push the new ear cushion in place.
      Vraag FixBot
      Voeg opmerking toe
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Left Speaker: stap 4, afbeelding 1 van 1
      • Remove the left ear cushion completely from the headset.
      • The left ear cushion will be on the side of the headset where the microphone and audio control is attached.
      Vraag FixBot
      Voeg opmerking toe
    2. Turtle Beach Elite Pro Left Speaker  Replacement: stap 5, afbeelding 1 van 2 Turtle Beach Elite Pro Left Speaker  Replacement: stap 5, afbeelding 2 van 2
      • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
      Vraag FixBot
      Voeg opmerking toe
    3. Turtle Beach Elite Pro Left Speaker  Replacement: stap 6, afbeelding 1 van 2 Turtle Beach Elite Pro Left Speaker  Replacement: stap 6, afbeelding 2 van 2
      • Use the opening tool to separate the orange plate from the black base plate.
      • Focus on the wires that are connected to the speaker.
      Vraag FixBot
      Voeg opmerking toe
    4. Turtle Beach Elite Pro Left Speaker  Replacement: stap 7, afbeelding 1 van 1
      • Using wire cutters, cut the two wires that are attached to the speaker.
      • Make sure to cut the wires as close to the speaker as possible, because these wires will be used in the next step.
      Vraag FixBot
      Voeg opmerking toe
    5. Turtle Beach Elite Pro Left Speaker  Replacement: stap 8, afbeelding 1 van 2 Turtle Beach Elite Pro Left Speaker  Replacement: stap 8, afbeelding 2 van 2
      • Replace the old speaker with the new speaker.
      • Using the soldering iron, solder the wires to the new speaker.
      • Make sure to solder the wires to their original locations on the speaker.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexis Uribe
528 Reputatie
4 handleidingen geschreven
Baylor, Team S5-G1, Williams Spring 2017 Lid van Baylor, Team S5-G1, Williams Spring 2017
BU-WILLIAMS-S17S5G1
3 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 3,678
